Posted By: Richard Nosker
Posted On: Friday November 24, 2017 at 9:58 PM
Apparently Paleobond is a cyanoacrylate ("super glue").
As such, it will attack paint and most clear plastic window materials. Plus, regular Super Glue is much cheaper. I've used this successfully, using the standard low viscosity version, to make these repairs. I use a thin wire, dipped into a bit of cyanoacrylate so a small drop forms on the tip. Then bring the tip up to and parallel to the trim piece. The liquid will suck under the trim piece when it makes contact, by capillary action. Sometimes a tiny piece of tape can hold the surfaces closer together, before applying the liquid, but keep the liquid away from getting too close to the tape. Have a paper towel ready. If any liquid gets on the paint, wipe it off immediately and all should be well.
glm 1932 rolls royce by Paul Patterson #23378
I know there've been earlier discussions, but can we have a refresher on by Mark Lampariello #23378.1
Mark, I hear that Paleo Bond works well. A local model vendor I see by Randall Olson #23378.1.1
Apparently Paleobond is a cyanoacrylate ("super glue"). by Richard Nosker #23378.1.1.1
glm 1932 rolls royce by Paul Patterson #23378.1.1.1.1
glm 1932 rolls royce by Paul Patterson #23378.1.1.2
You are welcome, Paul. So simple & better than a toothpick! (EOM) by Randall Olson #23378.1.1.2.1
I have found that Testors Clear Parts Cement & Window Maker works well. (EOM) by David Holcombe #23378.1.2
glm 1932 rolls royce by Paul Patterson #23378.1.2.1
glm 1932 rolls royce by Paul Patterson #23378.1.3
Paul, why don’t you send it back? (EOM) by Chris Sweetman #23378.2
Good suggestion Chris. If they don't respond, file a credit card / paypal dispute until they do. (EOM) by Frank Racibozynski #23378.2.1
Exactly Chris. by Mike Coupe #23378.2.2
Mike, nice one and full credit for checking each model before ….. by Chris Sweetman #23378.2.2.1
Unfortunately, it doesn’t always go to plan Chris, especially when Royal Mail or whoever by Mike Coupe #23378.2.2.1.1
glm 1932 rolls royce by Paul Patterson #23378.2.3
Paul, fully understand your concerns and great to know it is an easy …. by Chris Sweetman #23378.2.3.1
I don’t recall having any problems with my own Spa Croft Models. by Mike Coupe #23378.2.3.2
Copyright © 2018 Legacy Diecast Models and Diecast Zone
