Posted By: David Holcombe
Posted On: Wednesday July 25, 2012 at 8:07 PM
John has given some good advice. There is also the matter of construction
material. Today the two most often used in fine 1:43 cars are resin (a form of plastic) and white metal (sometimes confused with lead but a mixture of metals). The resin allows very fine detail and the white metal has weight and gives a sense of value. Lower ranges often use die cast metal and/or plastic.
Also consider the price range. 1:43 models range from just a few dollars to several hundred.
Whew! It's a wide area to consider. The great thing about Forum 43 is that the collectors here buy in all of these variations and some others that I haven't even mentioned. Welcome! And enjoy!
what brand? by gennady DARER #14325
Welcome to the hobby. You are correct, there are many makers out there... by John Kuvakas #14325.1
John has given some good advice. There is also the matter of construction by David Holcombe #14325.2
How much you want to spend per model is important as well. Some models............. by Randy Bahler #14325.2.1
